Biomimicry Creates New Tires
Biomimicry is the science that imitates nature to create new products.
Resilient Technologies, a Wisconsin based company, has created a tire that can't go flat.
Instead of using a pressurized air cavity, the tire design relies on a geometric pattern of six-sided cells that are arranged in a matrix like a honeycomb.
It has the same ride, reduced noise levels and heat generation as pressurized tires. The goal was to create an airless tire with uniform flexibility and load transfer that would endure tremendous wear and tear and still perform well.
The best design was found in nature, which was the honeycomb.
- See more at: http://www.inventor-strategies.com/late ... 3Mf3K.dpuf
TYRE WITHOUT AIR
Re: TYRE WITHOUT AIR
Seems to be very innovative and creative. Hope it will be in market soon.
